Billwill
Well I jinxed myself about 5 months ago when I stated that my 2002 CRD Alternator Litens pulley had never failed!
Three days ago as I turned into the entrance to my Complex the steering got extremely hard to turn!
I managed to then turn into my garage and lifted the hood....sure enough the Serpentine Belt had snapped!
The top-right idler pulley ie. nearest to the Left door was seized solid....other idlers pulleys seem OK.
About 5 months ago I had the Timing Belt replaced as a precaution and I told them to replace the Serpentine Belt and check the idler pulleys and tensioner.
I have ordered a new Belt but the local Agent states that the Pulleys are no longer available....I am going to order them and a Tensioner from Sasquach or other overseas suppliers but I am wandering as to the state of my Alternator Pulley!
This was 20 years old so could be bad but how do I test it?
If I put a 17 mm Allen Key on the pulley-end and hold it firmly I can rotate the pulley surface with difficulty with my other hand both ways about 90 degrees at which time it locks up!
Is there any sure way to test if the Litens Alternator pulley is indeed bad?
Years ago I discussed the Litens pulley in great detail on AusjeeppOffroad and Lost but I have lost all my documentation from those days as to the replacement procedure for the Litens Pulley....the local Dealers here are useless and will probably say I need a new Alternator!
Great fun working on the Jeep with a 5 month old replacement Metal Hip on my right side!!!
