mechanicboy
Anyone have instructions for the cylinder head replacement on the 2002 3.7? Step by step would be nice but I ad least need torque specs. Also are the head bolts single use?
I have it torn down to just the head and some of the front of the engine needs to be pulled. I was hoping, though I know it's not likely, that I could get away with replacing the head without pulling the entire front of the engine down. The problem is I do not see a way to take the tension off the timing chain and keeping it timed without doing so.
Thanks for the help!
