Dash Illumination
Prest989
Apex, NC
Once again I seek your help. After coming home from the lake today, I took my jeep to run some errands. For some reason, the dash, and the gear shifter illuminations, do not work. I cannot see my tach, speedo, or gear selection, however I can see my odometer and my fog light indication light. The interior lights, Cd player, and front socket all work fine, which would make me think it isn't the fuse. Any ideas?
06Liberty
Odenville, AL
there's probably a dedicated fuse for the intrument panel lights....have you checked just to make sure?
I had all my dash lights go out and the right tail lamp also (mine is an 05) It was a blown fuse. If yours is the same, it's the fuses in the dash when you open the drivers door. There is a panel there. In the owners manual there is a fuse diagram. I think it was fuse #9 on mine. But check the owners manual for yours as there should be a diagram indicating which fuse is which in there.
Prest989
Apex, NC
The fuse is the same fuse as the interior lights/cd player, and they work fine... I'll check again anyway.
