Daystar Spacer lift question
Wulfhound
Escondido, CA
A friend gave me a daystar lift off his 2003 libby. says it will fit my 2012 it was only used for 17k. Daystar said i needed a different kit. does anyone know if this one will work or do i need a different one?
TheBlueKJ
South Jersey
Does it matter? It will destroy your suspension and ride like utter :poop:, even though it's free it will cost a lot to fix the problems it will cause
dude1116
Pompton Plains, NJ
Eh I mean if he's replacing with OME, then Carpe Diem. Destroy the hell out of your stock suspension.
Wulfhound
Escondido, CA
I have been told by others taht have used this lift that they had it for yrs it worked out fine and this is only temp. until I can afford to get the JBA adjust a strut silver set up. although the run I did this weekend all i need is another 1" or 2 and the under armor ofcorse
I've never heard anyone in the last 10 years that has had it on for years and its been good.
For the time and effort it takes to install, buying longer rear shocks ( and should buy new front shocks you're close to a Ironman or OME full spring kit.
