Hello, I’m new to the site but not new to diesels. I’ve driven VW TDI’s for close to 15 years and did all my own work. My last TDI had 416,000 miles on it when some A-hole blew through an intersection and totaled it. If you want to check out the dash cam video, here is the link.
Looking for a replacement diesel, I purchased a 2005 Jeep Liberty with 91,000 miles. On the test drive I could tell it was way low on power, but I was just cocky enough to believe I could fix it, and the price was right. I noticed the check engine was on. The seller explained that he had done an EGR delete which caused the check engine light, which made sense. On my way home after driving at highway speed for one hour I stopped for fuel. After fueling up I was driving in town and 35 mph, the Jeep died. It was as if I turned off the key. No coughing or sputtering, just died. Yes, I'm sure I filled it with diesel. I had the Jeep towed home. It cranks but will not fire. I bought a scanner and pulled the codes. About 15 of them! After reviewing the codes, I noticed that most of the codes are low voltage. I understand the CRD's are voltage sensitive, so I purchased a new Duracell 800 CCA battery. I’m getting 12.2 Volts from a meter I plug into the cigarette lighter. I cleared the codes and rescanned. Same codes showed up. I checked the fuses and they seem to be fine. I also plugged a Noid Light into the fuel injector plug and it does not blink while cranking. I’ve go to admit I’m might be in over my head on this one. I don't understand, with good battery voltage how all of these sensors could be reading low voltage.
Also: Before scanning the codes I removed the Flow Control Valve just to see if it was clogged. Its been cleaned out, but the idiot that did the EGR delete never plugged the Flow Control Valve exhaust connection after the pipe was removed. So there was about a 1 inch connection blowing turbo boost into the engine compartment. Low power explained.
This is the report form my Torque Scanner. The code definitions following the word null are the codes I looked up. All others are directly from the scanner. I'll admit I don't know what the null means.
Fault log report generated by Torque for Android
Vehicle VIN: 1J8GL585X5W629541
Vehicle Manufacturer: Jeep
Vehicle Calibration ID: Not present
Current Fault Log
P0047: null Turbocharger Boost Control Circuit Low
P0091: null Fuel Pressure Regulator Control Circuit Low
P0489: null Exhaust Gast Recirculation Control Circuit Low
P0670: null Glow Plug Control Module Circuit Fault
P1251: null Vacuum Reservoir Solenoid Short To Ground
P2295: Fuel Pressure Regulator 2 Control Circuit Low
Pending Fault Log
P0091: null Fuel Pressure Regulator 1 Control Circuit Low
P0489: null Exhaust Gas Recirculation A Control Circuit Low
P0562: System Voltage Low
P1189: Engine Oil Pressure (EOP) Switch Circuit
P1251: null Air Mixture Solenoid Circuit Malfunction
P2141: 2) Exhaust Gas Recirculation Throttle Control Circuit Low
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
B2TAE: null Appears to be a Torque Software Nonsense Code
P2264: Water in Fuel Sensor Circuit
End of report.
Current Fault Log
Pending Fault Log
Historic Fault Log
End of report.
