I don't see how it'd snap an axle shaft. The sway bar's purpose isn't to act as a stop on the suspension. The strut is what stops suspension travel in the front. I removed and reinstalled my strut assemblies with the sway bar connected and the strut was at full extension.
woh that is not 100% true
only 50% true
the struts and shocks control drop or down travle ONLY if you have shocks or struts that are to long and they bottom out befor the weight of the jeep hits the bumpstop you will destroy them
as far as dissconecting the sway bar on IFS
I feel that it is to much work for to little reward
on rigs like the TJ or XJ you gain like 5" of wheel travle
on the KJ you realy gain almost 0" maybe 1" so not realy worth it
can it be done sure but does it realy help IDK
My take on the KJ has become what I heard a guy say about his YJ
"I know that I dont have the flex of a TJ ,I know that I will be getting air under my tires so I locked it to give me traction on air"
same goes for the KJ ,lock it so you get traction on air
then you can throw flex out the window
