door lock horn chirp
maantoline
beaverfalls PA
does anybody know how to disable the horn chirp when you lock your doors. 2010 liberty KK
DarkPassenger
Colorado Springs, CO
Yep, here is what you have to do:
Step 1 - Press and hold the "Lock" button on your key fob
Step 2 - Hold it for at least 4 seconds (but not more than 10)
Step 3 - While holding the lock button (after 4 seconds) press and hold the Panic button
Step 4 - Release both buttons at the same time.
If you need to enable the horn again, just follow these steps again. To stop the parking lights from flashing when hitting the lock/unlock buttons, follow these same steps but hold the "Unlock" button instead.
maantoline
beaverfalls PA
thanks. any suggestions if that doesn't work? tried it a bunch of times an won't disable the horn. does it matter if your in or outside the jeep. key in ignition or out?
DarkPassenger
Hmm, if that didn't work then I am not sure what the issue is. You don't have to be in the car, just within range for you remote to work. Just tried it on my '09 and it worked :shrug:
benibiker63
Hawaii
I just lock my doors/enable alarm by locking the door on the way out with the door switch. That way it doesn't beep.
maantoline
beaverfalls PA
i am going to install a remote start that utilizes my existing key fob. to start jeep you have to push the lock button 3x. so 3 beeps an then it beeps back to acknowledge the request to start. that's 4 beeps at 6am when i would be starting my jeep. kind of disturbing
maantoline
beaverfalls PA
the instructions from DarkPassenger did end up working. just be persistent. it will eventually work. remote start install was easy an successful. $ well spent an no annoying horn at 6am. thanks DarkPassenger
