My electric rad fan will not come on, I have tested the following:
swapped the Relay with another (has about 4 or 5 of the same relays for fan) still did not come on
checked 60 amp fuse with meter.... good
Hooked the fan directly to the batter both hi and low engage the fan
I know it could be the engine temp sensor, have not replaced yet, but i do have a programmed PCM coming because i figure i ma down to either the PCM or the temp sensor. The reason for the PCM is I have other issues like constant multiple misfires and crank/cam shaft errors.
My question is if i turn the AC on should the Rad Fan come on regardless of the temp?
I read some say it should and others say no its temp that triggers it on.
If it doesn't come on cold after turning the AC on is there a way to test the temp sensor with out replacing?
I can run it until it over heats and still don't get an error on the bluedriver about temp or the fan. but did get one a long time ago while trying to diagnose the misfires showing fan error.
I have a week until the PCM arrives so looking check a few other possibilities off the list
2008 Jeep Liberty
3.7L
79,000 KM
2008 Jeep Liberty
3.7L
79,000 KM
