I have 2002 Jeep Liberty KJ.
My engine overheated today after a 3km uphill drive. It started steaming a lot from under the hood, and then when I opened her up, I saw that she was boiling a lot of coolant from the coolant reservoir and onto the ground.
The temperature gauge on my dash registered a normal temperature (halfway between cold and hot). I had the heater on inside, and it was plenty warm on this cold day.
I stopped the engine immediately and haven't driven her from that spot.
Does anyone have any ideas as to how I can tell if it is the thermostat, the temperature sensor (is this even a separate thing), the radiator, or the water pump that is the issue?
I did get a new check engine light code that I haven't seen before - P0837 - am not sure if this is related or whether it is a coincidence. There has been a code of P0442 that has always been there that is still there.
In the last few days before the engine overheated, I also thought I smelled coolant coming from the car - am not sure if this is related either, as I drove 200km on a highway and in the city after that, with no issues.
Any thoughts would be greatly appreciated!
