icarl
Last weekend I snagged a branch underneath and now my speedometer does not work. I get error codes P0500 and P0836. I know P0500 is faulty speed sensor connection but what is P0836?
P0836 is the 4WD switch stuck,you did alot of damage didn't you?Last weekend I snagged a branch underneath and now my speedometer does not work. I get error codes P0500 and P0836. I know P0500 is faulty speed sensor connection but what is P0836?
Since you don't list any other skid but the front skid(meaning you don't have a ******/t-case/gas tank skid) I would assume you ripped the 4wd inticator switch wiring out just like the rear diff speedo sensor wiring.It does not mean you are in 4wd all the time since the t-cases have a manual shifter.Does this mean its in 4wd all the time or just the switch is faulty?
I would still check the wires for the 4wd switch, and make sure they're not cut or anything.
Sounds like you need to get some more skids too!
