ESP/BAS, Traction Control, ABS lights on
kinshinchi
Houston
Lately on my Jeep Liberty 2010 has this issue where if I hit a lot break during rush hours (sorry its houston and traffic is bad), all 3 lights will come on but when I get home turn off my engine and turn it back on, those 3 lights will be off. I am not its because bad break? when I hit break i do hear noise and that will cause the issue? or its bad sensor? Any insight thought will be appreciate.
First thing I would check would be the " brakes"
KKs goes through them pretty quick with the ABS and all it seems
While there check all wiring to the sensors
also go to ****zone and they can pull the exact codes for you
twowings
Tulsa, OK
Bad sensor, bad connector(s), damaged component(s), extremely worn brakes....if you are not a DIYer, then get a brake inspection and get the codes....
