SwiftyZenBadd
- Joined
- May 7, 2008
- Messages
- 13
- Reaction score
- 0
I was looking thru my owners manual, and happened to see the p/o did keep some records, but nothing more than oil changes. Im sending my truck into the dealership to see if there is a head gasket issue, but what i would like to do is change all the drivetrain fluids and use royal purple.(warranty doesnt cover regular maintenance.)
I looked thru the manual and only found a few caps, but nothing real detailed, such as where the drain/fill plug on the transfer case is, where are the front and rear diffs fill/drain plugs? I noticed the front diff has one for a 3/8 rachet, but not sure bout the rear.
In essence,
How much fluid does the ****** take:
How much fluid does the transfer case take:
How much fluid does the front/rear diffs take:
Where is the drain/fill plugs on the diffs:
What weight gear oil do the diffs take:
I suppose i could have used the search function, but i just got my computer back up and running after a virus crashed it, so im a bit impatient at the moment.
TIA-
Jeff
In essence,
TIA-
Jeff
