dude1116
Hi All!
Currently in the middle of replacing the breather on my front differential (2004 KJ 4x4). I managed to rip the hose off both ends (the vent dry rotted, will be replacing). I have a couple questions while I replace:
1) How much water/how safe do you think it would be to ride without the breather hose attached for a week (diff can still breath, just not extended. Won't wheel, obviously). Only reason I ask is because the dry-rotted vent's replacement will be here next Friday.
2) Those who extended their hoses: where did you put it? I was likely going to put it back in the same spot (under the battery tray, attached to the vent), but if I wanted to extend it a little higher, where's a good place to put the vent down? Or did you just zip-tie the hose to something without the vent?
3) The metal piece that was holding the diff end of the hose onto the dif is beyond warped and destroyed (I was a little stupid getting it off...). What did you use to re-attach the hose to the dif? I was thinking metal zip tie, but I will likely have difficulty taking it off if I ever have to again. Did anyone use plastic zip ties? Or did you all just re-squeeze the stock metal ring back around the hose?
I hope all of that makes sense! Thank you all in advance for your responses!
:cheers:
:cheers:
