Front Grip / Hand hold
Trodo
Orange County, CA
Okay, I looked all through the service manual, I can't find it anywhere, and I'm just guessing it's called a handhold. The one you grab hold when you're getting into the Liberty.
There's two screws under the rubber inserts... Please, what is the screw/nut/bolt size. What do I need to remove the hand hold and access under the trim peice?
waldn
Winnipeg, MB
If you mean the one on the driver's A pillar I believe I used a 7/16 deep socket on my 04. Seem to remember reading some where that earlier models had screws instead
Corwyyn
Southeast of disorder...
Yeah, the older models have Torx screws.
Trodo
Orange County, CA
7/16, that sounds right, I thought that a 7/16 seated but just couldn't reach. Thanks. That helps a lot. And I typed in the oh #*!@ handle but for some reason, nothing came up.
eddiev9
Fairfax, VA
Just for everyone's reference...
A 5.5 mm nutdriver will work on 05 models, too. O:) Just make sure it's skinny enough to reach all the way in there.
Trodo
Orange County, CA
Finally having some time to investigate the 7/16 issue after getting a set of deep sockets, that is way off. It's 7/32 to remove the two long screws.
waldn
Winnipeg, MB
Sorry my memory isn't what it used to be. I knew I shoulda gone out and checked first
