Offroad Bob
OffroadBob
The ball joint in my right front lower control arm came apart this afternoon. No warning or noises. Waspulling out of a buds driveway and the stud pulled out and went with the hub. Leftovers are on the ground. I’ve changed the before but not in this situation.
Does anybody custom build lower arms ? JBA does not list them. Neither iron rock or Rocky Outfitters list them. I have a 2.5 lift on the front with Rock UCA’s that are 4 months old. The rear was just built with an Iron Rock setup. Adjustable upper and lower arms put in a month ago. Alignment supposedly tested everything and said all was good. Looks like I’ll have to go stock. What is the best brand ? I’m going to change both while I’m at it. Good thing it happened where it did going 5 mph. 30 mins earlier was running 70 or so on the interstate! That would not have been good had it broke then. I’ll have to fix it where it sits as the fender is on the wheel. Attached pics are right front. Any tips on replacing or brand info would be greatly appreciated ! Thx
