Fuel Filter Question
kjpilot
Minneapolis, MN
I'm going to change the fuel filter. I see that Jeep sells what appears to be just the element for about $40, but I recall hearing that the fuel filter was more like $100. Can I change just the $40 element or do I need more components?
Tjkj says it cost $130 since the filter and regulator are one piece.
If you can get it for $40 an its the right piece then let us know.
kjpilot
Minneapolis, MN
That is what I recall too, but I looked it up in the parts pdf & found this diagram:
& these part numbers:
3 05069072AA 1 EN0 HEAD, Fuel Filter
4 06502756 2 EN0 NUT, Hex Lock, M8x1.25
5 52128698AA 1 EN0 FILTER, Fuel
6 06504502 2 J, T EN0 CLAMP, Fuel Hose, 1/4“
7 05014018AA 1 EN0 BOWL, Fuel Filter
8 04723907 1 EN0 DRAIN, Fuel Filter Bowl
-9 04723901 1 EN0 VALVE KIT, Fuel Filter Check
That ain't the fuel filter for the gasser KJ,that is for the CRD.The fuel filter for the gasser is on the front top edge of the gas tank.You will need to call a dealer to get the correct part#,it is not listed in the parts manuals since it is a "lifetime" filter and is not suposed to be serviced.
kjpilot
Minneapolis, MN
Gotcha. Yeah, that's the only reference to a fuel filter I can find in the parts manual. To the dealer I go I guess...(censored)
Is there any possibility of modification to use a standard (less expensive) filter from some other application?
It would cost more to fab something else to work then getting the correct filter since the correct filter also has the pressure regulator in it.
Atrus
Metro Detroit, MI
is there a way to remove just the filter element portion from the tank unit and put in an inline filter exterior of the tank?
kjpilot
Minneapolis, MN
$92.00 at Trademotion.com, and a fuel tank skid for $79.00. Skid Rows for the front & engine coming from JBA, & Super Skinks from Rock Lizard in about a month, then ready to roll!
LibertyOrDeath
For those that care, I saw that they have the 45RFE for only $2068 with $165 for shipping. I paid over $2500 for a re-manufactured 1998 Ford Escort transmission. I also saw on there a 42RLE/VLP anyone know what that is?
