Full Time light after transfer case swap.
vlad588
Vancouver
I’m installing NP242 transfer case in my 03 Liberty and i want to get the full time light to work on the dash. Does anyone know what needs to be done for that to work. Thanks.
u2slow
BC
I did your swap too and didnt realize they was a fulltime light until I drove a factory one years later.
I wondered if the lamp is simply missing from the dash cluster. I havent checked yet.
vlad588
Vancouver
From what I understand the lamp is missing on the dash, but I’m wondering if there needs to be modifications done to the wiring
CRD-Joe
I had the issue in my jeep it wasn't showing it either after I enabled the transmission in my scanner as being something like 4wd unit. You get 2 different selections and I wish I could remember them exactly, but unfortunately I can't. Needless to say I enabled the one that made sense for my Libby and the full time light stop working, after I picked the other option, the original one the full time light started working again. Sorry I can't remember the selections, but I do remember it disabled the light on mine.
vlad588
Vancouver
what kind of scanner tool were you using?
vlad588
Vancouver
Launch x431 v+ pro elite
Do you happen to remember what type of function this way. Like was it ecu programming or something else. I’m just trying to find a scanner tool that will do that, and the one you have is too expensive so i’m hoping to get a cheaper one that has that capability
CRD-Joe
You need a 2 way scanner that will allow you to make changes. It's been awhile but I was in the bcm and cluster/instrument section. It's in there that I was able to make the change. There are cheaper versions of my scanner, or if you find a mom an pop garage they may be able to help you for a small fee to hook up thier computer with you explaining what to try. There used to be a place that rented the Dodge DRB3 unit, not sure if they still do. Or there was an emulator as well.
vlad588
Vancouver
Thanks!
