Fuse box queston
JBDive
NC
I was trying to track down a problem in an 07 that I have a thread on elsewhere on here and I see it has these fuse holders of some sort for two of the fuses. One is white, the other is yellow and they pull out to disengage but how do you access the "cage" to change the fuse if you need to?
Image from elsewhere on the web, referring to the white and yellow cages.
They are secured for a reason. Why do you want to mess with these?
jeeptorino68
Oregon
I have a similar issue where the white one keeps losing connection, radio, dome lights, etc go out. If I wiggle It, they Come back on how can I get a reolacement or swap the fuse...probably just need to hit the junkyard,..
