Gascap and Check engine light
Life Liberty Happiness
Tonganoxie, KS
About a week ago my wife called me to let me know that the check engine light was on in our 08 Liberty with 50K on it. I was pissed and asked if it was driving ok or if she noticed anything odd. She said the odometer said gascap. She tightened it to a few clicks and restarted. It still said gascap. When I got home I hooked up the trusty scan tool to it and came up with a code i dont remember but it was like evap pressure or something. I figured yeah that was it. Reset the codes. I looked through the manual for the jeep and it says it tests the gascap and if it is found faulty twice in a row it will put on the MIL. Well now that the MIL is reset and out we have been driving it and every time the jeep starts it says gascap, but no MIL. We have put like 200 miles on it and maybe 15 trips. I bought a gascap today and put it on and it still says gascap every time I start it. Anybody have anything similar or know where to start?
Vjesse
NYC
just disconect the negative or black cable of the battery for 30 sec that it
Tonganoxie, KS
Tried it and its back on now with the check engine light agian.
Time for a new battery. Mine did the same thing when it started going bad
I'm guessing This will be the root then. Here in Kansas we have been having 95+ degree weather I wonder if that is making it worse.
Shwanzig
Boulder, CO
Also when changing your battery don't forget to change your spark plugs too, they probably need to be changed as well.
Tonganoxie, KS
Sorry everyone for the late reply, I have been traveling a lot recently for work.
Awesome reminder for everyone. I know we have a tendancy to forget to change them out. However, I changed them out when I bought the Jeep at 42k and she is just over 52k. I have plans on changing them next oil change.
I had a similiar issue with my 08 Liberty. It was the ESIM.
Were you able to get just the module or did you have to buy the entire canister and all? Was it cracked or did it show any visible signs that it was broke? I'd really hate to throw parts at it just to see if they stick. I assume that was a dealer only part?
yellocoyote
NW Chicagoland
Your check engine light is still on? I had this with my KJ this week, and it was a gas cap issue as well. Tightened it down, and let the jeep cycle on and off a few times... CEL eventually went away.
Tonganoxie, KS
Still on. I have bought 2 new caps. Always tighten to 2 or so clicks. I am thinking its the esim, does anyone know how to test or check it or should I just shell out some money and get one??
It started as just a gascap light, then went to mil codes 456 and 457 I think. I am checking all the hoses and they look good. I tried checking continuity on the esim and cant get any. I tried forcing it closed both directions and no continuity either.
Vjesse
NYC
wow thats crazy !!! sorry I dont kw what to tell you but let us kw when you fix it good luck
Tonganoxie, KS
I think I have it fixed.:whip: I changed out the esim. Luckily the dealerships in the area had them in stock and after it and the gasket and tax it was less than 12 bucks to fix. It has been driven a few days and the computer reports that it has completed the full evap system tests!:happy107: Now to try to return the gascap I did not need. . .
Xodius
Las Vegas, NV
Is the 08, like the 02's? If so check your hoses. I posted the other day about it. Simple fix.
MaryRosales
Mexico
thnks for all the recomendations.. a I am a women and I am single¡¡¡¡ I have a one 07 liberty whit 77,000 km.. and I feel so bad when a see one messenger in the liberty.
A. Sandoval
pagosa springs
I had the same situation on our 2013 LIBERTY. Tried many time to resolve with no success. Check engine light and gascap warning returned every time. Finally, the battery was draining overnight, worked it out after a week. The positive top post connector was corroded and so I replaced it. Oddly enough, the check engine and gascap warnings did not return. My theory, the sensors work off of electrical signals and the low electricity to those sensors created a confusing error code problem
