Get Ready for the Outdoors with Special Rebates on Warn Gear!
carid
Preferred Vendor
Cranbury, NJ
Hey everyone! We're excited to share some top-notch winches from WARN that can significantly enhance your off-roading and recovery needs. Whether you're driving a Jeep, truck, or SUV, the WARN VR EVO and ZEON series winches provide remarkable power and reliability. With features like waterproof construction and fast line speeds, they're built to tackle any challenge you might face in the great outdoors. Plus, they come with both wire or synthetic rope options to suit your specific requirements.
If you're looking for versatility, check out the WARN ZEON Multi-Mount Electric Winch Kit. It's perfect for those who need a portable solution that can be easily attached to a 2" hitch receiver. This kit not only offers powerful performance but also the convenience of a multi-mount system, making it a great companion for your adventures.
For the ultimate performance, the WARN ZEON Platinum winches are the real game changers. They include advanced features like a state-of-the-art wireless remote that controls the winch, clutch, and even two additional accessories. This series is designed for enthusiasts who demand the best in terms of speed, control, and durability. Ready to take your vehicle's capability to the next level? Explore our selection and find the perfect WARN winch for your adventures!
WARN® - Winch
Features:
  • A powerful series-wound motor and planetary gear train deliver faster line speed under load, with lower amp draw
  • IP68-rated waterproof winch construction keeps the elements out
  • High-performance Albright contactor delivers maximum reliability
  • Control packs can be relocated for low-profile installations
  • Durable, one-piece cast-aluminum tie-plate for added strength and durability
  • Two-in-one remote with wired AND wireless options for ease of use and versatility
  • Available with wire or synthetic rope
  • Limited lifetime warranty for mechanical parts and 7 years on the electrical
  • Designed, engineered, and tested by WARN engineers in the U.S.A.
WARN® - ZEON Series Multi-Mount Electric Winch Kit
Features:
  • Fast line speed with low amp draw minimizes strain on charging system
  • Powerful and quiet 12V DC series wound electric motor
  • Fast and reliable 3-stage planetary gear train with 216:1 gear ratio
  • Ergonomic, easy-throw clutch lever
  • Lightweight, large diameter, heat dissipating winch drum reduces rope wear
  • Powerful automatic mechanical brake holds the full-rated load with superior control while winching
  • Convertible control pack can be removed and mounted separately from the winch to allow winch to be mounted in tight spaces (requires Control Pack Relocation Kit, sold separately)
  • Remote control with 12’ steel reinforced cord and rubber overcoating
  • Cast aluminum housing with unique modular, symmetrical appearance has an IP-68 rating, the highest attainable for ingress protection, to keep out the elements
  • Satin black powdercoat finish to resist corrosion
  • Corrosion resistant stainless steel hardware
  • Both wire rope and synthetic rope winches available in WARN Multi-Mount portable winch carrier that fits 2" hitch receiver
  • Multi-Mount kits include winch, hawse fairlead, carrier, and 7.5’ of wiring for the front of the vehicle
  • Dimensions: Integrated configuration – 24.25"L x 7.15"D x 10.52"H, Low-profile configuration – 24.25"L x 7.15"D x 7.84"H
  • Comes with detailed installation and user instructions
  • Limited on mechanical parts
WARN® - ZEON Series Electric Winch
Features:
  • Limited lifetime warranty on mechanical parts
WARN® - ZEON Platinum Ultimate Performance Series Electric Winch
Features:
  • Includes 80' of 3/8" (9.52mm x 24.38m) aircraft-grade wire rope and a roller fairlead
  • The Remote Controlled Clutch is engaged and disengaged with the Advanced Wireless Remote. The remote controls winch-in, winch-out, and freespool operations. The manual clutch has been eliminated. No more re-engaging a manual clutch, with frozen fingers while standing in the mud
  • The Advanced Wireless Remote gives you total control in the palm of your hand, allowing you to control the winch and up to two accessories. This sophisticated, advanced remote provides operator feedback on vehicle battery charge and winch motor temperature, controls operation of the winch clutch, and more. Includes USB charging cable and car charger adapter
  • All-new high-speed motor, stronger gears, and heat-treated ring gear deliver 20% faster line speed, best-in-class efficiency, and their highest durability rating
  • Durable aluminum structure with flat black powder-coated finish and stainless steel fasteners delivers durability and maximum corrosion resistance-exceeding 400 hours of salt-spray testing
  • Large diameter alloy winch drum with steel sleeve is strong, light weight, reduces rope wear, and has an integrated rope anchor for easy rope installation
  • Extreme waterproofing meets rigorous IP68 standards the highest rating in the WARN Truck/SUV winch lineup
  • Automatic mechanical cone brake offers excellent control while winching
  • Convertible control pack can be attached to the winch or remotely mounted, allowing for various winch mounting options and looks (Relocation kit required and sold separately). The new-style control pack with contactor and advanced controls gives you extreme reliability and weather resistance.
If you want to learn more about the Warn brand, please click the link below:
carid
Preferred Vendor
Cranbury, NJ
Don't miss out on our Incredible Warn Rebate Promotion! From August 1 to September 30, 2024, enjoy great savings on select Warn products known for their durability and reliability. Get a $50 rebate on our sturdy Axon & VRX Winches, essential for any off-road challenge. Plus, upgrade your vehicle's safety and style with $100 off our Zeon and VR Evo Bumpers, crafted to endure the toughest conditions. Make sure to check out the PDF form to claim your rebate and make the most of this fantastic opportunity to gear up at a great price!
You can browse the full catalog of Warn products at the link below:
See other active promotions and coupon codes here:
