Getting out of 4wd Lo
coffman45152
Ohio
Help Please, (05 liberty Sport/90,000 miles/automatic)
I slid off the road and hit a sign going around a 90 deg. turn about 200 yards from my house the other night due to ice. Cracked the Passenger Side Bumper cover and turn signal. I've only used 4wd once or twice previously. Shifted the transmission into neutral and was able to put the jeep into 4wd Lo. Drove home at 25 mph. Now i cannot get the jeep back into 2wd. I followed the owners manual recommendation about driving 2-3 mpg and trying to shift back into 2wd while in neutral. The 4wd lever will not budge. I've pushed extremely hard multiple times, still no luck.
Any recommendations before i spend my life savings at the mechanics shop.
Thks.
Chris
jeeptorino68
Oregon
try driving it in reverse for at least 20 ft, then try shifting out of 4low. this sometimes helps
Are you pushing straight down, or to an angle? Follow the pattern on the shifter (kinda have to push it in that direction). It's tricky the first few times. :)
TwoBobsKJ
Northern Ohio
Pull the lever toward your right knee while the ****** is in neutral and you're moving less than 5mph. When the lever moves to the left push it down to 2wd.
It's a good idea to put your Jeep into 4wd occasionally to keep the transfer case fluids moving and engaging the clutches.
dude1116
Pompton Plains, NJ
I'm remembering the shift pattern as such...
|2hi
|4hi
|||Neutral
|4lo
So I would say push the lever to the right a bit if you need.
Am I wrong? The way you're explaining it is like this (I think)...I forget though (it's all natural at this point...)
|2hi
|4hi
|||Neutral
|||4lo
TwoBobsKJ
Northern Ohio
|2hi
|4hi
|||Neutral
|4lo
|2hi
|4hi
|||Neutral
|||4lo
That's correct. When going from 2wd to 4lo you pull the handle up till it stops, push to the right, then pull up again to 4lo.
When going from 4lo to 2wd you push the handle down till it stops, pull it to the left, then push down to 2wd.
Now for those of you with RHD Libertys/Cherokees you would be using your left hand and pushing/pulling the handle in the opposite direction. :freak3:
coffman45152
Ohio
Gentleman,
Thanks for your input, however still no success. I've tried all your recommendations and i still cannot get it out of 4wd Lo. I can't even get the lever to go into Neutral.
Any additional suggestions that i might try?
get all 4 tires off the ground then try it again, sounds like you have it bound up real good
coffman45152
Ohio
I put the jeep up on blocks so that all 4 tires could rotate freely. Turned on the jeep and put it in Drive then Reverse several times all while trying to Get it out of 4wd Lo. No Luck.
Are there any sensors or fuses related to this mechanism or am i looking at something mechanical? I only drove the jeep about 200 yards when i put it in 4wd Lo and even then i did not exceed 30 mph.
All suggestions welcomed.
Chris
moparman
Baltimore, MD
It takes a fair amount of effort to snap it free if it is stuck. No need to be gentle.
One time my sister went to rent a KJ at the airport, somebody put the transfer case in "N", nobody (bro-in-law, rental car employees) could get it back in gear and they had to take another rental.
coffman45152
Ohio
Problem Solved,
Soaked the linkage on the transfer case overnight in Penetrating Oil. Tapped the linkage on the transfer case a couple of times and out of 4wd Lo it went. Tested the lever multiple times and everything works like new. Guess i need to start using 4wd a little more often.
Thanks everyone for responding to my questions.
Chris
TwoBobsKJ
Northern Ohio
That's good news!
Ya, take in the mud occasionally and throw it in 4wd. Keeps things operating properly and prevents weird problems with the transfer case.
BMCD
Just has the same problem with my 2007 Liberty. A short/slow drive up the block while trying to move shifter solved the problem.
