Hello Everyone,
I recently got a '06 Jeep Liberty KJ CRD from my family, (it was used as a winter vehicle in the Rockies, its been in the family since new)
Mileage is 98k miles, body is in good shape, but there are a few issues.
For now I'd like to focus on one that's got me a bit stumped.
There has been a consistent noise coming from what I thought was the front tires, it sounded somewhat like a bulged tire (cyclic throbbing sound) but has been getting louder and louder, and it now sounds more like a bad bearing. Its quite noisy, noisier than the diesel engine, louder than the wind noise on the highway.
Tires are winter tires on the front, and AT tires on the back.
I swapped the tires from front to back, the noise did not follow the tires (tires appear good, no bulges, no damage)
Steering left and right while driving and hearing the noise (checking front wheel bearings) does not change the sound.
Checking the wheels for play while up on stands, shows that the bearings seem ok, no free play.
I removed the front drive shaft (propeller shaft) drove around and the noise did not go away (if anything, it seems to be getting worse)
Question #1
As I removed the front drive shaft (front CV joint/u-joint, connected to the front differential) leaked out a heavy (seemed green) of oil out of it?
Is the front drive shaft CV joint filled with oil? (the shaft is originial oem)
The 6 bolts that hold the CV joint in were seeping oil out as soon as I removed them, I'm assuming this is not normal?
The front drive shaft rear CV joint seems ok, nothing leaking out, smooth quiet movement
Visual Inspecting the front 1/2 shafts, both seem to be in good shape, no torn boots, no leaks.
Question #2
Could this noise be the wheel bearings? despite the fact that there seems to be no play and no change in noise when steering left/right?
When I get a bit more time, I will check the front differential (open cover, check condition, hopefully there is fluid in it) seems hard to get to.
Thanks for taking the time to read my post,
Looking forward to any suggestions!
Cheers
Tazmool
Question #1
Question #2
Cheers
Tazmool
