Headlight question
nate5238
I have stock blubs, today my right headlight stopped working on lowbeam but worked fine on high beam. This means I need new bulbs right?
big steve
roseville MI
i have the same prob my high beem works and the low dosn't i went and put a new one in and it still dosnt work. somebody said it was the relay switch. but i dont know where that is any sugestions
chaz0_man0
Petoskey, Michigan
here what I got..
nate5238
How can I figure out what my problem is without going and buying new bulbs?
Cableguy
Flori-duh
if your left headlight is still good, and your right is blown, swap the bulbs from side to side. if the problem stays with the bad bulb (ie. right goes to left, now left dosen't work) odds are it's the bulb.
hope it helps
-brian
