Hello from Ohio
librarian
Ohio
Hello all. My wife and I just bought an 04 Liberty Limited with 94K miles on it. My wife has always wanted a Liberty and this is her/our first one. Overall it seems in pretty good shape. I have seen the carfax report and it was regularly serviced at the same Chrysler/Jeep dealer for the vast majority of its life.
I have plans to take it to our local Chrysler/Jeep dealer and have the diffs and transfer case fluids changed. I will also have the cooling system power flushed. I saw on the carfax report that the transmission was serviced at about 60K miles. I think it is time for a fluid/filter change there as well. The oil was just changed in the engine so I think it is OK for now. The car has new pads and rotors so that is not an issue either. All the power windows are working. The AC blows very cold. the body and interior are in nice condition and the exhaust system is new fromt he muffler on back. Once all the fluids mentioned above are changed, I should have a pretty good baseline on service from that point. I looked closely at the water pump and could not see any wobbling or leak/weep issues with it. I will watch that closely. The coolant hoses all look very good. Any other suggestions you all can give me about preventive maintenence will be very much appreciated. The only cosmetic issue on our Liberty is the alloy wheels. They have quite a bit of corrosion on them and I would appreciate any advice on how to clean them up or have them refinished if that is not too expensive to do.
Although this is our first Liberty, I have also owned in the fairly distant past, a cherokee wagon (early 80's) and one of the little pickup trucks also from the very early 80's. Both of those jeeps gave me good service and would go anywhere I wanted to take them.
TwoBobsKJ
Northern Ohio
(welcome)
What part of the state are you in? There are quite a few Ohioans on here and we occasionally get together for Meet & Greets.
Sounds like you found a great Liberty - that's low mileage for an '04. The maintenance you're having done is a good idea, with the only further suggestion being a brake fluid flush & refill. That's a commonly overlooked maintenance item and at this stage of your Jeep's life it's not the mileage but the age that creates a problem with fluids.
Others will chime in with suggestions on the wheels - several have refinished or painted their wheels due to corrosion so will have better ideas on how to take care of them.
Welcome to the KJ family!
Welcome.
librarian
Ohio
Thanks for all the welcomes. The suggestion about brake fluid is a good one. Will get that done too. No, our liberty does not have heated seats. My wife likes cloth better. I like leather, but whatever my baby wants is fine with me.
Again, thanks for the warm welcome. I have already been reading a lot and have learned a great deal.
librarian
Ohio
My location in Ohio is a village in Clinton County named New Vienna. It is right on SR73 about half way between Wilmington and Hillsboro.
