Rebuilding my 02 Liberty that was wrecked in the front. We used all new parts from an 05. My 02 has a 2 wire plug to the electric fan, the 05 has a 3 wire plug. So, we cut off the 3 wire plug and put the old female side of the 2 wire plug onto the fan and connected it to the High speed side, then then the low speed, then both together. NOTHING.
My temp gauge inside will not move past 1 needle mark before half. It was 82 degrees yesterday i let it sit at idle for 1hr and the electric fan would still not kick on. I OHM tested the coolant sensor by the alternator and it seems to be working fine.
Possibly relay under the battery box? If i unplug the coolant sensor the fan kicks on like it should. How do you test the relay?
Im still running the mechanical fan so maybe the coolant is just not reaching the correct temp to kick on the fan. BUT, it was hot yesterday, i strongly feel there is a problem somehwere.
Is there any other ways to trick the system into turning the fan on? Im at a loss.
