GloryIsForever
Hello everyone, sorry I didn't post an introduction before this but I'll be quick, Name is Craig. I live in FL. I recently moved back here after a few years on Camp Pendlenton as a 1371/Combat Engineer in 1ST CEB. I am 24 with one beautiful boy and a little girl on the way. I'm serving out the rest of my enlistment at home on Terminal Leave/Disability. Couple Tours and now I'm ready to move on even tho I would rather continue because I loved what I did. So as for experience under the hood I have very little. I'm more used to explosives, guns, ect. I tool around a bit and help a few friends and learned what I could and now have a decent understanding of the basic fundamental. I also own a 07 GSXR 600 and work on it and do all its maintenance. I plan on starting school in Sept. for Marine Specialty basically all things boat. Now back to the issue. I finally decided it was best to reach out for some advice before I get to deep.
My Brother(also USMC) and I own a 2004 Jeep Liberty 3.7L V6. While driving on the highway he started experiencing some overheating issues and some power loss so I assumed right away because of the overheating that a number of things could have happened. It ended when I did compression tests and found out that 2 cylinders were low. I inspected the plugs and I visually inspected the cylinders with a snake LED. Turns out coolant was pooling in the cylinder. So that leave two options. Either the head was cracked or the gasket had blown. Either way the head is coming off. So after a long while and plenty of tests and precautions I went ahead and started removing everything needed. (This is all for the passenger side head only. Yes I know I should do both but we honestly cannot afford it right now.) So now I have the cam cover off and the cam sprocket removed with the chain wedged in place. I have marked it all and had TDC so when I replace it, everything. Anyway I'm stuck at the head. It won't come off. All the bolts are removed.. I moved the wedge and ziptied the chain to my thumb so it didn't drop when pulling on the head. But it will not come off. So I'm stuck.
I hope I explained it all properly. I will post pictures here in a bit to give you an idea of what I'm looking at. And also hope this is in the right thread. I'm new to the whole forum thing. Thanks in advance for your help.
