Rethink your tire size first thing
a 32 inch tall tire requires 3.5 to 4 inches of lift
Harder to get that height anymore since JBA doesn't make his coilover kit
Then anything much over 3 inches you need JBA upper control arms
Then next a regear, problem is 4.10 is as low as you can go which in reality is not low enough for 32s
I know I ran 32s and 4.10s for over 100,000 miles on my 04 ( with 4.5 inches of JBA lift, 265-75-16s on Moabs
Always wanted 4.56 especially on any type of hilly roads or pulling a trailer
Next you can not cut these like another vehicle, some try but it is taking the strength out of the unibody
Now 2.5 inches of lift which is easy to obtain with OME 927 front and 948 rear springs and either Bilstein or OME shocks you can run a 31, like 245-75-16 or I prefer 265-70-16s ( either same height, 265-70-16s just fill the Moab out better ) which I run on Moabs on my 03 , but again with 4.10 gearing, you can get by with stock gearing but harder on transmission and you will lose power and gas mileage of course
then bumpstops of course front and rear , can provide info on what works best there as well later
Now start with questions
