Mr.Paul
Help with OBD P0158 & P0161 Codes
Greeting. 2004 Liberty, 3.7 6 cylinder with 62,000 miles. New platinum plugs, oil change, pcv valve @ 60,000. Shortly after purchase of this vehicle at 60k and a solid pass at the smog station, the OBD started kicking up a P0158, which is a o2 sensor, bank 2 downstream (passenger side after cat).
After purchasing a new sensor and replacing it, no luck and same code. To ensure that the new sensor was not bad, I removed the driver side sensor downstream and used it in place of the passenger side sensor. Same results after resetting the computer. (battery disconnected for 30 minutes).
Can of SeaFoam in the gas tank. No change. Then magically 500 miles later, light went off. Light off lasted several days and now it is back on and kicking up the P0158 code with a new code also, which is P0161.
Is this an injector issue? Engine seems to run okay with no noticeable problems. I have been tracking gas mileage and libby is getting 17mpg average. I did read somewhere that the libby's like copper plugs, not platinum. Could this be a problem?
Any ideas before I have to mortgage the farm and take it to the Jeep dealer?
Thanking all for reading and possibly responding.
Paul
Paul
