BlackWolfLiberty
I am thinking about adding a hi-flow catalytic converter, it's 2.5 diameter piping correct along with how many o2 sensors on it? one or two?
I'm pretty sure that I have 3 catalytic converters, and I have a 42RLE... Maybe a '02-'03 thing?If you have the 45RFE trans you have 3 cats,42RLE trans you have 2 cats.
In only about 10% of the cases of bad cats does that hold true.Easiest way to tell if cats are bad is to get under your KJ and tap on the cats with a rubber mallet. if you hear anything rattling inside, they are bad.
OEM cats made after about '00 flow better then aftermarket "high flow" cats do.troy's right about the aftermarket "highflows" messing with the o2's, have had several that opted to replace downstream cats with the high flow cheaper cats and it ended up burning up the upstream cats
however, those who replaced ALL the cats with the highflows haven't seemed to have any problems with the cats or the o2's
im under the assumption it's a backpressure / flow difference between the OEM and aftermarket cats that causes the problems
That's a stupid question. Who would buy a 2wd Jeep?
Hopefully I fixed it, anyways I don't drive her much she is an 06 with barely 12K miles on her. I have a 6inch BDS Lifted 2007 Dodge Ram 1500 that I normally drive but I love that little jeep!
