Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Release the tension by placing a 15mm wrench(or ratchet with socket),to do so you want to tighten the bolt and the tensioner will swing up releasing the belt tension,then remove belt.Follow the diagram on the raditor support panel to place belt back on and then release the tension on the tensioner again to slip belt on the last pulley and your done.Takes about 2 min tops,no need to remove pulleys unless you are replacing them to.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
