How to choose the correct O2 sensors
hcch
Hi I am experiencing high fuel compsumtions on a 2007 Limited KJ, I have never change any of the O2 sensors.
That is the option I have in mind, the thing is the I undestand I need 4 2 on each side, but I do not know if this option will fit on all 4 places?
Also if there is any better brand that you may suggest based on exoerience I will appreciate it.
Gyro
Nova Scotia
That is the correct sensor.
It will fit all positions.
Have someone with a code reader check for codes, to see which sensor is faulty,no need to replace all sensors.
Gyro
hcch
thanks for your kind replay, the car has just left my old trust mechaninc he overhaul the ****** service it replace the front struts but my daughter complains about the car drinking 2 much gas I use low octane on it. and since the sensors are the OEM ones since out the dealer when new back in 2007 I belive it would do no ham.
Also tha last sparks I change were some iridium and I think to swap them fo the Ruthenium ones to see if that can also help the gas usage.
Check the MPG with the other guys on here before you buy any parts, it's a 2 ton truck with the aerodynamics of a brick....
Jeremy-WI
Home
Jeep KJ likes copper core NGK ZFR 6F-11G gap set at .040.
Jeeps have never been famous for good gas milage.:D
Gyro
I ran autolite double platinum in the 2006 for a couple years and it didn't affect the mileage. Wasn't any change when I went back to the copper plugs either
dtennes
Do you really need new sensors, or do you need to replace sensor connectors (shorted wires), or do you need to really replace the sensors? A clean emission report would indicate that all three components are actually ok, and you are probably using bad gasoline. If you fail an emissions test, the results will tell you exactly which cat failed, which will narrow down where you need to focus and replace parts.
If sensors actually need replacing, go here, read it carefully, then do a parts search for the two upstream and 2 downstream sensors.
https://www.ngk.com/oxygen-sensor-position-guide
They are all different and must be installed exactly where they belong. The link will explain all of it in explicit detail, pay attention. If you have a mechanic install them, confirm that the mechanic understands what goes where (I marked the boxes and made sure he was aware).
Use NGK sensors, replace all 4. If 1 is bad the rest are not far behind.
