jhblackwell
You would have to on an '06. I assume an '05 would be similar. Actually, you remove the plastic bumper cover. Following is part of how I installed my front shackles with how you remove the grill and bumper, etc.I know...how did I screw up on this?
So the M bolt/screw, I put it in the wrong way. No prob, just slide it through the way I put it in. Nope, fell over in the bumper. So now to get it, do I have to remove the bumper to get to it? If so, how shall I do that?
TIA.
pop hood and release clips at top of front grill, starting at headlights
continue releasing clips along top of grille
lean grill top out to release lower clips and remove grill.
unscrew each turn signal lens.
pull assembly out of slot in fender cowling
remove bolt from fender cowling at headlight
remove bolt on bottom of cowling by bottom of radiator, each side
pry plastic pop rivet off at bottom, each side
pry pop rivet off at leading edge of front fender well lining
slide screw driver, etc., behind head of pop rivet and carefully pry out
release clip at top of cowling by wheel well
gently pull on turn signal harness rivet and remove from cowling
twist turn signal bulb socket and remove. cowling should drop off
front of KJ with plastic removed
remove all three nuts from tow hooks and remove
remove "w", or double bolt leaving spring clip nut in place
remove access hole cap
tow hook access hole ready to modify
Once you have the access hole cap off you can retrieve the "M" bolt. Hope this helps.
