HOW TO: Install Sirius Starmate
robotmonkey
I made this little how-to and posted it in the Sirius Backstage forums. Since I plugged your site (your forum and how-to's helped me a lot), I figured I ought to join and post it here as well. Here it is.
ROBOT MONKEY'S JEEP SIRIUS INSTALL
Okay, strorg put up a great how-to for installing a Starmate Replay in his red Jeep Liberty, so here's a slightly different approach I used for my black Liberty. The install I did was easy to do and is very low profile.
Here's what it looks like right now:
Pretty fly, eh? That's how I roll.
All cables are hidden, except for the DC power cable and the annoying plugs on the side of the Starmate Replay. I only made two permanent changes: 1) A small slot cut in the top of the center dash junk bin and 2) A small slot cut in the bottom of the under-armrest storage bin. Neither of these are visible. The install is pretty much done except for the DC power. I will hardwire the power into the Jeep so it is completely invisible and I don't take up my precious, precious dashboard power socket.
Disclaimer: I'm no expert. You could break your Jeep, void your warranty, electrocute yourself, develop eczema or even suffer occasional drowsiness if you follow these instructions. Also, this how-to should work for many differently colored Jeeps, but I only know for sure that it works with black ones. I suspect it will go faster with red ones, though this hasn't been proven empirically. Yet.
YOU WILL NEED
Phillips screwdriver
Soft membership card/credit card
Rotary tool like a Dremel (relax -- it's nothing major)
Torx bit for drill / Torx screwdriver (for removing third-brake light housing)
Flux capacitor
STEP 1 - ANTENNA INSTALLATION
I followed strorg's outstanding directions for this. Rather than reinvent the wheel, I'll just show you a handsome picture of the antenna in action. It isn't really in action -- I ran outside to snap the pic, but you can put on your imagination caps for that.
Image 1. Handsome antenna in action.
I will add that, like strorg, I also had the wire exit the third brake light assembly to the side where the gasket is thicker. It comes out just under the left screw, where the compression is (probably) the most.
Step 2 - RUN ANTENNA CABLE
Following strorg's instructions, run the cable through the interior on the driver's side. When you get to the bottom of the A-piller, pop open your fuse panel and drop open the trim panel under the steering wheel.
Image 2. Opening the trim under the steering wheel
See the two arrows? That's where you pry the panel out and down. Or down and out if you're in Beverly Hills. This is what you get:
Image 3. The dash got pantsed.
Now, run that cable into the fuse area and under the steering wheel. Let's pause here and open up the center dash panel.
Step 3 - OPEN THE CENTER DASH PANEL
There is a philips head screw in the back of the junk bin (next to the power socket). Unscrew it. Do you see the two arrows in the image below?
Image 4. Do you see the arrows?
I put the ignition in the "on" position and moved the gear selector all the way aft to give myself a little room.
Stick your credit card or whatever in the center of the panel seam, pull it out enough to slip your index fingers in and then slide them out towards the arrows. I used a soft Giant supermarket bonus card, because it is unlikely to damage anything. The top part of the center piece should pop out. Ease out the bottom part, too. Don't pull too hard -- your HVAC controls have wiring harnesses connected to the back of the panel. I was able to work with them connected, but you can easily remove them and pull the whole panel away from the dash. So here's how it looks for me at this point:
Image 5. Center panel pulled away.
STEP 4 - ROUTING MORE WIRES
Do you see top of the junk bin in the pic below? I carved a slot in the far left top of the enclosure with my $25 Black & Decker knock-off of a Dremel. You can see wires going in there.
Image 6. Center panel pulled away.
Now, you see that bundle of wires disappearing into the oval shaped cut-out (shown in Image 5)? That runs down to floor.
Take your antenna cable and run down into the hole the arrow is pointing to in this image:
Image 7. Ignore the test-installed Starmate Replay.
Now, fish the antenna cable up into that bundle of wires. Stick your hand in the hole the go into and fish the cable out. Run it into the slot you cut in the bin.
If you are using an AUX input like me, grab a 6' angled mini to RCA patch cord . Stick the mini side in the slot and drop that down the same hole you fished the antenna through. I used the patch cable that came with my home kit. Bring it out the hole in the bottom, just like in Image 8.
Image 8. Good enough for now.
STEP 5 - FOOLING AROUND WITH THE ARMREST BIN
Now I'm taking the bin out of the armrest. There are seven screws, indicated by arrows below that need to come out. FYI, the two screws in the very bottom of the bin are shorter than the other five. Also, Yogi is smarter than the average bear. Or so the government would have you believe.
Image 9. These screws come out.
Once the bin is out, I Dremeled a little slot in the bottom right for wires to feed through. No image of that, sorry.
Now that the bin is out, you can rock the entire center console side-to-side a little bit. Remember that audio patch cord? I used the little bit of give in the center console to feed that cable all the way back and brought it up in the cavity below the bin. You can see the audio cable as well as the bus cable for my AUX input device. Make sure you aren't putting cables where they can get damaged or worse, interfere with your parking brake, rear power window wires, et cetera.
Image 10. I feel so exposed.
The bin goes back in and the seven screws replaced. I got the AUX input device from these people and it adds two AUX inputs. It plugs into the CD changer control jack in the back of the head unit and fools the OEM head unit into thinking that there's a CD changer. The second set of inputs is for my MP3 player.
There is enough room to fix the AUX input box below the storage bin. If I decide I need a little more room in that bin I may move the AUX input box there.
Image 11. Storage bin replaced.
STEP 6 - REPLACING THE CENTER DASH PANEL
Before you replace the center panel, pull excess antenna cable and sound cable through the slot you cut in the junk bin. I also pulled up excess DC power cord and zip tied it all behind the scenes. Panel goes back. Screw goes back in junk bin.
STEP 7 - FIXING THE STARMATE REPLAY IN PLACE
This is what surprised me. After fooling around with all sorts of stuff and contemplating drilling through the suction cup thingy, I discovered that I can just wedge it in the junk bin compartment if I configure it correctly -- and it won't move! See how it's set up in the image below?
Image 12. Study this like a menu in an unfamiliar restaurant.
Note how Screw #1 in the back is squared up and how that screw is also set to give a slight angle. Anyway, slide the whole thing into the junk bin. Look at the image above. That is actually the right orientation to slide it straight back into the bin. If it feels loose, just open the angle a little bit at Screw #1. Whatever you decide upon, make sure that screw is tight.
Image 13. Mount in place without receiver.
The mount swivels on the end, so I have the Starmate Replay tilted up and towards the driver.
Image 14. A winner is you!
You can see how the head unit is set for the non-existant CD changer that is really my little AUX input box.
LAST THOUGHTS
Everything was easier than I expected, but then I had strorg's great how-to and a lot of outstanding how-to's on Jeep KJ Country. That Jeep site has a how-to section that has great instructions for things like CB radio installation, which can help you planning your own Sirius install.
The last piece of the puzzle is to hardwire the power so I don't take up the socket and I don't have any cables exposed at all (except the little bundle that plugs into the Starmate). Whenever I do that I plan to write it up if there's any interest here.
Also, it occurs to me that if I can affix a tiny drawer slide to the top of the junk bin, I can attach the Starmate Replay to a hinge and then attach that to the slide. Then I can still use the junk bin for, well, junk. I'll look into this.
Finally, if you screw things up too badly, use the flux capacitor.
LASTEST THOUGHTS ON HARDWIRED POWER
Okay, I hardwired the power. First, I ordered this cable from Xact for about $15. You could probably do it cheaper, but I just wanted to get it done.
Then I picked up an Add-A-Circuit doodad from my local Napa Auto. I made sure that the Xact cable had the correct inline fuse (it did) and connected its red wire to the Add-A-Circuit's red wire with a butt-end crimp connector. Taped over the join with electrical tape.
I'm not going to get into detail with where or how I routed the wiring -- you can see how I did things in the above pictures.
Anyway, I popped the Add-A-Circuit doodad into the fuse location for the front power socket. Or maybe the rear. Damned if I remember. Anyway, it's an "always on" connection. You can choose a switched location if you like.
Image 1A. The Add-A-Circuit doodad.
I took the Xact hardwire cable ground lead (the black one) and crimped on a wide spade connector. I taped over the join with electrical tape and opened the panel to the left of the driver's right foot. You can see some screws going into the vehicle body and some other wires being ground on those screw. I loosened a screw and added the Xact ground wire.
Now, the Xact cable's jack is, for some reason, longer than it needs to be. I cut off part of a black plastic felt tip pen's barrel and made a plastic washer to slip over the jack. I superglued it on. This way I can be sure that I am not jamming it too far into the Starmate's power socket. My fancy-pants pen mod amounts to a homemade washer.
Image 2A. See the pen mod?
Image 3A. Et voila! Dash power socket now liberated.
gsbrockman
Sand Gap, KY.
Great article.
I have the Sirius Sportser in my 2003 Dodge RAM 2500 Crew Cab 4x4 CTD and I purchased an inline 3.5A mini-blade type fuse holder and just wired into the cigarette lighter circuit for my 12V + switched power and ground. I also purchased the Aux Input device from Metra Electronics so my Sirius is now connected directly to the stereo (RAZ---am/fm/cassette/cd) thru the CD changer port.
Greg
robotmonkey
gsbrockman said:
... and I purchased an inline 3.5A mini-blade type fuse holder ...
Any trouble finding the fuse holder? I looked at my AutoZone for one of those Add-A-Circuit dealios and couldn't find one there. Maybe I'll try NAPA or Pep Boys.
billforde
Seaford, NY, USA
gsbrockman
Sand Gap, KY.
Got mine at NAPA.....the fuse holder was about 6 or 8 inches in length with the fuseholder directly in the middle.
Greg
mattstueve
Great writeup! I just installed my Starmate Reply in my (black) Liberty. I'm going to order one of those aux inputs that you linked, and I'd also like to wire up the power direct. Can you provide a little more info on how to do that? I'm assuming I'd have to cut the lighter portion off of the supplied power cord, then connect the end of the remaining wire to the circuit extender part you referenced?
Thanks again!
robotmonkey
mattstueve said:
... I'd also like to wire up the power direct. Can you provide a little more info on how to do that?
This is what I plan to do:
Get an Add-A-Circuit thingy. That will go in a fuse socket. Attached to that? One of these. Yeah, it's for Xact models, but they are negative ground like the Starmate Replay and have the same voltage requirements (I think). I'll replace the 3 amp slow inline fuse with the 2A that the Starmate Replay calls for.
Then I'll ground the ground wire and should be good to go. All the wires will be run behind the scenes.
I think I'll drop the fuse holder/Add-A-Fuse/Add-A-Circuit thingy into the radio power socket in the fuse panel. That way it will turn on and off with the car. That might end up getting changed to an "always on" circuit, so I can use the pause feature when I run into the grocery store or whatever. Dunno.
Keep in mind that I don't know what I'm doing. If -- IF -- my install that I documented above looks good and is useful, it's because I was able to rely upon people who do know what they're doing. That's why I gave the shout-out to the Jeep KJ folks on Sirius Backstage.
What I'm saying is: If you follow my how-to or my proposed plans and your Jeep becomes sentient and kills you, it will serve you right for following the directions of a monkey. A robot monkey.
billforde
Seaford, NY, USA
If i remember correctly, there are two fuses for the radio. One always has power and the other has power when the Jeep is on.
old and in the way
Pittsburgh, PA
I have the Navigation radio in my 05 Renegade, with the 6 disc changer in the back. I am using the Sirius Sportser.
Sounds like after reading about the aux input thingie, it would plug in to the changer input, and I would lose the CD changer? did I understand that correctly?
robotmonkey
That's right. I get two aux inputs with that device. I use one for Sirius and the other for my 20 gig MP3 player. I haven't used CD's or needed a changer since I got my MP3 player. YMMV!
BluPhant
Connecticut
Thanks for the how-to! I've moved it to the how-to section for easy reference. Quick note, for my XM radio, I found a ignition-switched wire under the drivers side panel (big honkin red wire) and soldered in an lighter female under the panel there . (Got it from Radio Shack). Plugged in the XM lighter thing, wrapped the whole thing in electrical tape (so it doesnt come apart) and it works nice, nice and is all hidden.
If you ask really nicely and wait a month, I might be able to snap a picture ;)
-Blu
robotmonkey
Hey, glad it's of use to anyone.
I have the power hardwired now. Give me some time and I'll snap some pics and do a quickie write-up.
-- Herr Doktor Robot von Monkey
robotmonkey
Small update: The USA-Spec aux input device crapped out. I heard similar complaints from other USA-Spec users, so I replaced it with a PIE adapter (same basic operation). I put the PIE adapter in the open space to the left of the HU behind the scenes.
The PIE adapter only has one set of inputs, so I share the 2.5mm plug with my Starmate-R and my MP3 player. I thought about installing a splitter and a second cable, but I just don't care enough. Apathy, thy name is robotmonkey.
Also, I'm happy with the adapt-a-fuse thingy on the always-on circuit because it let's me pause playback when I run errands, so I left it the way I installed it (I updated the HOW TO above with the hardwiring power info).
libertyman
What a great how-to, I bought one about a month ago and was not sure how I should install it until I saw this, thanks
icarl
Peace Country
The link is dead for strorgs how to and I would like to know how to run the antenna wire from the rear break light to the front of the vehicle. I'm thinking maybe through the 'ceiling' but it looks rather difficult. How is this done?
gsbrockman
Sand Gap, KY.
Remove the 3rd brake light and you'll soon see what a breeze it is to route. I ran mine down the passenger side, all the way to the A-pillar, and then through the side of the dash.
Greg
icarl
Peace Country
Greg
I did look in there. Your antenna wire must be thicker than mine then. Mine is just flimsy and there is no way I could route it across the length of the roof without it snagging up somewhere in there. The only way I can see doing it is to take all the side panels off so I could lower the ceiling panel on one side to guide it along. Or if i had a very long, strong and thin wire to guide it to an exit point.
icarl
Peace Country
At first I tried to run the wire down the center using a sail baton but got snagged at the roof cross member. So then I tried running the wire to the drivers side and out. Pulling the wire along the drivers side I could tuck it back in under the ceiling panel and weather stripping as the panel is a loose fit. I then ran it down the A pillar to my Sirius Starmate 4 radio. Any loose wire was tucked under the panel with a plastic card. Nothing left to do but enjoy the radio! (whistle)
robotmonkey
Sorry, I've been in the process of opening my restaurant and haven't been paying attention here (or anywhere outside of the four walls of my place).
Anyway, iCarl's method is exactly what I did. The wire tucks easily under the stripping on the driver's side above the windows.
