HVAC is stuck on Defrost? What happened to my controls?
richtj99
Hi,
My wifes 2005 KJ Limited is having an issue with the blower controls. The controls for speed (1-4) work, the controls in the middle (pointing at head, or feet, or both, or recycle, etc) dont work, they are stuck on defroster (which I put it on yesterday) - Off works as well. The controls on the right (cold - hot) also are in working condition.
Any ideas on how to fix it?
Thanks,
Rich
richtj99
Is there a way for me to test which it is? i guess a leak is probably something I cant test, but the blend doors actuators, is that a replaceable part? If I pull the blower apart, is that something I can see?
Thanks for the fast response!
Rich
jeepkj02
Holland, Michigan, USA
Blend doors....I know they had a problem with that on the GC WJ's. Heard it was a huge pain to fix. Think you have to remove the dash.
I would check into a vacuum leak before I assumed it was a blend door. Dont hear about the blend doors going bad on the kj.
richtj99
I hate to ask what might be an obvious question, but how do I check the vacuum to see about a leak? Can I do that myself?
jnaut
Seattle
I don't have it handy, but I believe that my Chilton's manual does a pretty good run-down on how to detect vacuum leaks in the HVAC system. I'd strongly recommend running by a good auto-parts store and picking up a manual if you're going to do this work yourself.
