Idle Searching 450 - 650 RPMs
J33Pfan
NY
What are the most magical fixes for Idle searching 450 - 650 RPMs then stall for these Libbys?
IAC is 6 mos old. I replaced the spark plugs today because I hadn't in a while (The old ones looked good enough to go back in) No improvements.
My OTC scanner shows the 02s reading are good. TPS too. Performance is great.
Did you buy a Mopar IAC ?
Have you cleaned the iac port to remove carbon?
