chadstoks
Hey everybody!
I have a 2003 Sport, 3.7 155,000 miles.
For the last few weeks she's been idling much higher than it should be, especially when I first start it. I did a little reading on here and based off some suggestions I removed the IAC and cleaned it and the throttle body. It seemed to make a little difference but it didn't completely fix the issue.
It seems to act up more when it is cooler outside but it has its moments at full operating temperature as well. I've also noticed that it seems to be affecting dropping into 'passing gear' while doing 45-50 going down the road. I can give full throttle and it will remain in the current gear, but not all the time, as in the same 10 minute window it will act up and act normal.
I feel like I need to replace the TPS or IAC but would prefer to not just throw parts at her and see if they stick.
Any advice??
Thanks in advance!
Any advice??
Thanks in advance!
