Ignition actuator is broken, the key won't turn as far as it used to. I maybe still have the run position, I just can't crank it with the key, but it was running fine like an hour ago. This car is my only mode of transportation so I can't just go get a new actuator. Anyway, I put the key into run, and shorted the pins on the starter relay and im getting it to crank, but no start. Fuel pump is coming on, so I'm thinking maybe I dont actually have the run position anymore either, just accessories? Any tips on getting this thing to start? I don't have a long enough t20 so I can't open up the steering cover, thinking of just breaking it and grabbing a screwdriver.
