Im going to do the clevis lift
mag03kj
LOST
I'm going to do the clevis lift but i need to know what all im going to do and need and i have looked at the How-To's put really dont know what all i'm going to need. I also want to know if im going to have to do a alignment? Im tired of seeing it sit stock and want to upgrade in the KJ World :p
Thanks,
Mag
mag03kj
LOST
ya i got that part but i need to know about the shims from boiler and the rear lift
For doing all of that then its the same as doing a full spring lift lift almost have to R&R everything like you would for that.
But with all of that done and on an 03 you may gain an inch total if you're lucky. Your springs have more than likely sagged at least an inch so lots of work for not much really.
Bure Agahli
cheap is expensive
It's the Wesway lift...:D
Way I see it, you get practice taking the front shocks out of the KJ and you can use the stuff later on when you get the funds to buy new springs and shocks.
x2...one of the very many benefits to the WW lift... (WW is WesWay):cool:
mag03kj
LOST
im going to go cheap right now money is gettin low..lol
blue_kjR417
Platinum Renegade
Jonesboro, AR
Yes, mag what you're describing is the WesWay Lift as tony, tom, and hj said, if you're having trouble figuring out how to do it, what is involved, and so on check out the WesWay Lift sticky in the Lift Kit Section and I'm working on an in depth how to as well.
mag03kj
LOST
10-4 i tried to do the front but cant get it to move with a local store here opens (MSI) monday...im going to get the smallest bottle jack and then go ahead and do the front but ya my coils are sagged thats why im going to do the WesWay lift but later after funds are there im going to do a full lift.
blue_kjR417
Platinum Renegade
Jonesboro, AR
The best thing to do is use a scissor jack like the one that comes with your liberty. Place it between bump stop and the groove in the UCA then jack the jack and it will push the whole assembly down, but the strut will stay in place. When you reach the point you want, tighten the bolt and remove the jack. That's what I plan to put in my how to, so if you can stand to wait until next weekend I will have a full how to on it.
mag03kj
LOST
Ya it will prolly be next Sat. bc my papa is in the H. and dont know when he will get out but i want to to the clevis right now so that i can maybe get back to stock day 1 sitting...how far on the clevis did you go?
blue_kjR417
Platinum Renegade
Jonesboro, AR
I lowered the clevis until I measured 3/8" from the bottom of the strut to the bottom of the clevis ring. I measure it in the little slice in the clevis where the bolt goes across.
