Hey guys,
I have a couple of Bazooka tubes laying around (I don't even know if they work) and I wanted to install one. I'm quite the beginner when it comes to car audio. I was able to find a manual online to install it but I'm still a little hesitant.
I'm sure a couple of you have installed Bazooka tubes in your Libbys and I was wondering if I could get some pointers. There are apparent three options to choose from:
Option One:
For the most versatility the Remote Turn On Wire should be connected
to the source unit's "Accessory", "Auto-Antenna" or "Remote"
lead -- any of which will supply 12 Volts positive when the source is
turned on. When you are using this configuration, the Quick
Disconnect YELLOW On/Off Jumper Loop MUST be disconnected
from the wiring harness.
Option Two:
If the source does not have an Auto-Antenna lead (or if the Auto-
Antenna goes down during tape operation),you can connect the
Amplified Bazookas' Remote Turn On Wire to an accessory or ignition
point at the vehicle fuse block. In this configuration, the
Amplified Bazooka will be on whenever the ignition is on. This
method may allow noise or turn-on-and-off transients to become
amplified when the source unit is not in use. When you are using
this Option, the Quick Disconnect YELLOW On/Off Jumper Loop
MUST be disconnected from the wiring harness.
Option Three:
The Amplified Bazooka has a built -in Auto Turn-On Feature. If
you choose to use this feature, the Amplified Bazooka will turn on
automatically whenever there is music present at the inputs (high
level or low level input). Please take notice of the Quick Disconnect
Yellow On/Off Jumper Loop located on the Amplified Bazooka
wiring harness. SAS ships the Amplified Bazooka with this Jumper
Loop plugged into the wiring harness. When the JUMPER LOOP
plugged in, the Auto Turn-On Option is in the ON position and the
Amplified Bazooka will turn on automatically when it senses any
music at the inputs. The ORANGE wire should not be connected
to anything if this feature is being used. Be sure to insulate the
end of the ORANGE wire so that it will not short to ground, as this
may damage the Amplified Bazooka.
Which one did you use? Of the multiple wires coming off the Bazooka harness what do I need to hook to the Factory headunit? Also what's the easiest way to run the power wire from the battery to the tube in the trunk?
Option One:
Option Two:
Option Three:
