LibertyFever
I'm interested in leasing a North Edition Patriot for work. Can somebody please explain the 4WD operation to me? Is it a true 2WD until you put it in 4WD Lock or is it an AWD?
Thanks for the info Marlon JB2, I didn't know you were a "Patriot" expert too rollinglaugh.gif
FDII isn't worth it due to the drastic fuel economy decrease. Might as well buy a KJ at that point...
Let me clarify... if you do a lot of highway driving, it isn't worth it. If most of your driving is in the city, the Patriot still wins.
However with the FD II package, the Patriot sits higher, comes with skid plates, better weather stripping, insulation, etc. It's a real Jeep instead of being an AWD Caliber...
hmmm...because?You forgot about the suspension reinforcements.
All of this is true. But if this is just a work vehicle.... why?
hmmm...because?
It's 2WD unless it senses slippage.
Then power is transferred to the axle that needs it.
To LOCK it in 4WD, then pull the handle. This makes sure all 4 wheels get power.
So from what I've read it's actually front wheel drive 2WD until 4WD is required or locked in.
So here's the North Edition Patriot that I'm looking at;
http://www.jeep.ca/en/patriot/patriot_nth.html
The "automatic" transmission appears to be the Continuously Variable Transmission (CVT2) which I'm not crazy about and likely Freedom Drive I.
I'm still undecided. I'd like to have a 4WD or an AWD regardless of the manufacturer.
If you are not sure of the CVT, can you get one with a standard shift and 4wd?
I've never seen a North Ed. here, well maybe South Ed...
If it's FDI, basically AWD, but you can lock it. If it's FDII, it's AWD, lock it, and low range.
