JeepLibertyKK
- Joined
- Dec 1, 2013
- Messages
- 25
- Reaction score
- 7
I had a problem with the drivers' door interior handle, where it seemed really loose and like something was breaking. Easy to access and it turned out there was a pin that had worked its way up, to the point that the handle was flopping around in its mount. I noticed a spring that had no tention on it, so I thought maybe it had broken. Opened up the passenger side and saw how the spring was mounted; with the drivers' side pin back in place, I was able to re-install the spring properly. Or did I? When I looked at images online, I found some had the spring mounted like mine, and others had it mounted lower. (See images)
Any idea what might be the proper spring installation for the 2012 Liberty Sport?
Thank you
Thank you
