Patman1901
- Joined
- Mar 14, 2022
- Messages
- 10
- Reaction score
- 3
Hi, Just bought my first Jeep, 2003 liberty limited. its just getting to 140,000. It ran fine for 2 weeks then as im driving it just dies,like the key is turned off. so the first time i kept trying to get it started again and it acted like it was out of gas...even though it was 1/2 full,the guage does work.After about 30 minutes it started and i got backon the road, it drove fine for a couple miles then died again,Its an automatic so i coasted to a stop and same thing,this time it didnt seemtowant to idle but if i kept therpm's up ( 2,500+)it would stay running enough to get into drive and run down the road for another couple mile,.All the way home..
So i figured fuel pump...So i got a new one from autozone,the cheaper one,not delphi, cuz im cheap..
Anyways it was identical to the original and went in just fine,. the fuel line connectors fought me to release from the pvc fittings on the top of the tank,but i won,now i also had replaced the fuel filter assembly before this because i heard that might be the problem and i figured at 140,000 it was due,. i got that through amazon.it too was exactly the same as the first one,
so after all that it still is doing the same thing,
Ive checked the pressure at the fuel rail test port on the passanger side,by the way it the v6 4.3l, and i dont get gas of any real pressure,and that was true before i replace the pump/filter and still now
ive double checked the quick connectors at the fuel rail in and the two coming out of the top of the pump assembly,when i turn on the ignition the isnt 12 vdc at the electrical connector above the tank but when i turn the engine over its getting 12 vdc ,ive even unhooked the quick connectors at the tank end and fuel rail input then turn it over for a sec and im getting gas coming out so so the pump is moving gas but its like not strong enough
the engine is back to cranking over then almost starting to starting then only running at high rpm but wont stay running on its own.Ive had a shop check it out and paid $140.00 for him to tell me what i already knew!So its been sitting for over a month now and im really frustrated
can i put an electric fuel pump on in line? and also what about cutting out the quick connectors and sw?itching to hose clamps
