4) ORI struts 14" long
Currie IFS center diff, Ford 9" with 5:13 gears
RCV custom CV axles
Howe Performance power steering pump, reservoir and cooler
Grand Cherokee (WK) parts
front bearing hubs
cut down steering knuckles
tie rod ends
Chevy suburban steering box & Idler arm
The rear
Dana 44 out of a JK with factory electric locker and 5:13 gears.
custom 3 link mount,
removed the fuel tank, muffler and exhaust system, rerouted complete exhaust.
The fuel tank is an modified fuel tank from an old Wrangler.
fuel tank is now where the spare tire was mounted from factory.
clocked the transfer case to center the front drive shaft.
Built a 10" cradle drop to hold the steering box and the Currie diff. The control arms are about 10" longer then the factory a-arms and mounted to the cradle.
Just a few of the things
Oh and when they were starting to mock up the rear
