Jeep Overheating while idling
sebastien7
Arizona
2003 Jeep Liberty V6 200k miiles
While sitting idling in line or waiting to pickup someone up all of a sudden temp gauge goes to H and steam starts seeping out. Happened a few times now- neither AC or heat is on at the time.
Checked coolant levels which are fine (flushed a couple of weeks ago installed new radiator a few weeks ago) and it doesnt do it while driving.
Checked fan by turning on AC and it kicked on but not sure it was on when it was overheating.
Also, wife blindly put coolant to the brim after the last time it happen - should I lower the level or is it ok?
Any ideas? Thanks.
CzarKJ
Townsend, MA
Did you use the correct coolant?!?
Sent from my iPhone using Peanut Butter
sebastien7
Arizona
Like I said above I tested the fan by turning on A/C but maybe it didn't kick on when temp is high and the a/c is off? anyone think this would be the issue or because it kicked on with the a/c on it's fine?
nchorselover55
Cedar Point, NC
Fan probably not kicking on due to temp. If it starts overheating again, turn on the AC and see if the temp starts dropping.
CactusJacked
Chicago Suburbs
Not fine. The A/C-on overrides the temperature control and automatically kicks the fan on. But, that is a good temporary way to force the fan on to bring engine temps down until you figure out why the fan isn't going on when it's supposed to.
