Jet Performance Module
cvt8474
Michigan
Hey guys,
I'm looking at putting a Jet Performance Module on my '09 RM ed. and wanted to know what you guys know or think about them. Are they worth the money for the extra power provided? I'd probably only go with the Stage 1 seeing I haven't done any other mods to the Jeep. Also, seeing this doesn't reprogram my computer will it void my warranty? Has any noticed an improvement in gas mileage....not that expect great mileage from a Jeep, but more is always a plus. thanks.
jnaut
Seattle
Hey guys,
If I'm correct, there's a Jet and a Jet II for the libby. The Jet II requires you drive with premium 91 octane while the Jet gives you performance gains (although not as much as the Jet II) but still only requires regular gas. So pick your poison carefully.
And x2, I believe it will void your warranty, so you should wait until your warranty is up, or do what many others do: remove it before taking to the dealer.
desertkj
Arizona
I would strongly recommend against the Jet modules. Not only does it void your warranty and supposedly require higher octane fuel, but I have also seen instances (not with the KK, but with other vehicles) where dyno testing of the Jet module actually showed a decrease in performance.
