808inthe949
- Joined
- Jun 16, 2021
- Messages
- 95
- Reaction score
- 39
First, I know coming online to ask for help with a sounds is ill advised. But, im at a loss. No codes, cold a/c, no driveability issues or overheating.
KJ doesnt make any weird engine noises, until this morning that is. Dropped fiancé off at work, no noise. Dropped her sister off at work 5 hours later and upon returning home I hear a rapid ticking intune with the rpm. I have not done repairs for at least 5 days before today so nothing new to cause an issue that wouldnt have been there yesterday.
When I go under the hood with a rubber hose (fuel line) I can not locate the source. When I use a long metal bar (3/8 round stock), it seems to be coming from the ac unit. not the ********* condendser but the part with the pulley ( I sound so smart; sarcasm). Not the pulley itself but the internals behind the pulley. Using the hose/bar there is no tick from under car at oil pan, exhaust manifold, cats, etc. From up top, no noise at either valve cover, any of the pulleys, intake manifold, throttle body, elec fan, power steering pump. Noise is louder that a pcv ticking but not as loud as a knock. Rpm goes up, so does noise. (in speed not loudness or intensity)
Removed serpentine belt for testing, noise still there. Not any worse or any better. Noise does not change with ac on/off. Noise does not change when in any gear. Does not go away after 2500 rpm like exhaust manifold crack. No difference between cold or warm engine. All fluids are at capacity and well within service window (oil<1000miles old, trans fluid<5000 miles old, power steering <5000 miles old)
No Leaks (other than my front diff but thats unrelated I think)
Any suggestions to try and find the problem are appreciated
