Thanks to a fellow member here, I found out that the older KJ mopar tow hook accessory kit would work for the KK as well. I got the kit ordered through my parts department for about $80.
With the older kit, you get two hooks. With the new KK tow hook kit, you get one hook for the passenger side. This is because of the power steering cooler being mounted on the left.
I had to remove the mount for the two lines and reroute the upper line to fit behind the tow hook. I then had to get some convoluted tubing and zip tie a 6 inch section to the line, just to be on the safe side and make sure nothing rubs a hole in it. I did this later that day, so the convoluted tubing isn't pictured.
Anyways, it took about 20-30 minutes to install. Super easy. My KK even left a present on my stall floor. Dirt clods.
Sorry, but they are cell phone pics. That is the only camera that I have on me at work. It's not bad, but not as clear as I'd want.
