i have an issue with air getting in the power steering and foaming the fluid. I have checked all connections and replaced o-rings on pressure and return lines at rack, the high pressure line was replaced by the PO right before i bought the jeep and it had air in it when i bought it. Bled it out good and it was fine for about 2 months now i i can bleed it its fine even running with the tires lifted. i take it down the road 5 miles and its got air in it. i moved the outer end of the rack and pinon bellows in and the inner tie rods didnt seem soaked in fluid. Its really not so much an issue with it loosing fluid other than what it pukes out the top of the reservoir when i shut it down after its full of air. For the life of me i cant figure it out, about to just throw a new rack in it to see what happens. Its a CRD if it matters. the pump is different on them but not the rack.
