KJ 2006 3.7L Engine Temperature Slightly Low
Morgan
Hi, my Liberty 3.7L 2006 engine temperature gauge is always slightly lower than middle. Any suggestions on possible causes?
Morgan
Have you replaced the thermostat?
Nope. I thought that the thermostat will either be stuck open or close. Could the thermostat cause this? Picture attached.
Just wondering if a lower temperature thermostat had been fitted.
DadOSix
Cumberland, MD.
I don’t see a problem there.
Those are not the most accurate gages. I have an IR temp gun that I use when I want to know for real. Has a lot of uses. Block temp. Rotor temp - when you are looking for a caliper that hangs up once in a while.
Why do you think it is low?
Morgan
Thanks for the advise, I assumed the gauge is very accurate. I'll measure get an IR temp gun and also verify real temp with diagnostic tool.
