Hey everyone,
I need to make a clarification here. The KK has no vacuum lines that control the HVAC at all. There are 3 electric actuator motors.
1 - behind the glove box. This one changes the setting to bring in air from outside or to recirculate the cabin air.
2 - to the right of the driver’s right knee, the lower position. This is the blend door actuator and changes the heat/cool setting by mixing air from the heater core and air conditioning.
3 - to the right of the driver’s right knee, the upper position. This is the mode door actuator and changes the vent position the air comes out of. If the gears break, it gets stuck on defrost.
For #1, you have to remove the glove box to get at it. For #2&3, you have to remove the kick panel below the steering wheel (comes out like the glove box does) and the sound insulation above the driver’s feet. You can unscrew and detach an actuator motor from its position, keeping the wiring pigtail attached, and move the climate control knob and test it to see if it functions. If it does, then your problem is the air distribution box, and the gears on it are likely broken.
